分类:新闻中心
发布于 2021-12-02 20:48:04 +0800 CST
12月6日,7.1被官网强行修改为stable!
What's new in 7.1 (2021-Dec-01 16:07):
MAJOR CHANGES
!) updated Linux Kernel based on version 5.6.3;
!) completely new NTP client and server implementation;
!) completely new User Manager implementation;
!) merged individual packages, only bundle and a few extra packages remain;
!) new Command Line Interface (CLI) style (RouterOS v6 commands are still supported);
!) support for Let's Encrypt certificate generation;
!) support for REST API;
!) support for UEFI boot mode on x86;
NETWORKING
!) CHR FastPath support for "vmxnet3" and "virtio-net" drivers;
!) support for "Cake" and "FQ_Codel" type queues;
!) support for IPv6 NAT;
!) support for Layer 3 hardware acceleration on all CRS3xx devices;
!) support for MBIM driver with basic functionality support for all modems with MBIM mode;
!) support for MLAG on CRS3xx devices;
!) support for VRRP grouping and connection tracking data synchronization between nodes;
!) support for Virtual eXtensible Local Area Network (VXLAN);
ROUTING
!) completely new BGP implementation with performance improvements;
!) completely new IPv6 stack;
!) completely new MPLS implementation with interface lists, multipath and LDPv6 support;
!) completely new OSPF implementation with performance improvements;
!) completely new routing filtering with script-like rule syntax, RPKI support and large and extended community filtering;
!) support for IPv6 ECMP and VRF (including VRF-lite);
!) support for IPv6 recursive routing and policy routing;
VPN
!) support for L2TPv3;
!) support for OpenVPN UDP transport protocol;
!) support for WireGuard;
!) support for ZeroTier on ARM and ARM64 devices;
WIRELESS
!) completely new alternative wireless package "wifiwave2" with 802.11ac Wave2, WPA3 and 802.11w management frame protection support (requires ARM CPU and 256MB RAM);
以上是官方公布的7.1版本更新内容,当前是testing测试版本,非Development 开发版本(6.49是最后一个v6版本),从开始发布7.0开始,7.0beta版本只有8个,7.1的beta版本只有6个,7.1的rc版本只有7个,然后就到了7.1版本!现在v7的很多功能都没完善,还在不断的修改打补丁,我估计是要配合新品上市,干脆就这样发布了!v6都会有bug,何况v7,反正就是一个版本号!
注意到:docker并没出现在7.1的更新内容里!估计还要等后面的版本!
觉得有帮助?
请作者喝杯咖啡 ☕,你的支持是最大动力
